Old 07-10-2014, 11:13 PM   #5 (permalink)
Hondamate
wreck front - '98 honda civic hx
Originally Posted by RobertISaar View Post
based off of raw numbers with no scale, sounds like manifold pressure in kPa?
Come to think of that, I remember looking at the air filter to see if it was clean. Do you recommend k&n air filter for reduced lod?
There is a reason why TPS and LOD are different numbers. A given TPS will not always give you the same engine load. There are way too many variables including rpm, air temperature, humidity and more.
When it gives me lighter lods I'll have to see what else is going in then
