Old 07-12-2014, 12:18 AM   #851 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
One limit is the very high voltage associated with it. But maybe you could build a boost stage that takes maybe 150v and sends it up to 300v, and then use that for the bus for the AC controller.
Batteries can be had in smaller amp-hour sizes (25, 40, 60 amp-hour) so you can avoid the boost converter (more weight, lower peak current) if you are OK with double or triple the battery connections. 320V of LiFePO4 cells is 100 in series. Using 40 a-h cells, you get a 12 kw-h pack. Not sure what sort of range you are looking for.
