Old 07-12-2014, 03:03 PM   #29 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Depends
Originally Posted by figit090 View Post
What about the brake booster when the engine is off?
Also, does an engine with a manual transmission use any fuel if coasting down a hill with 0 throttle, being pulled by gravity above idle RPM?
If yours is a fuel injected engine, the computer might recognize the loading paradigm and provide no fuel while the engine is being driven by the tranny. Certainly a carbureted engine will continue to burn fuel, but only at a slightly above idle rate as the increased vacuum pulls a little extra fuel through the jet.
As for the brake booster, if you're still in gear but letting the car pull the engine, you're getting a strong vacuum into your reservoir the whole time (unless it's a diesel, YMMV). And even if you're coasting in neutral you should still have enough vacuum in your reservoir for a couple of stops.
If not, consider building or buying a supplemental reservoir to tuck into one of the unused spaces of your car, to provide backup.
