Old 07-13-2014, 05:19 PM   #1 (permalink)
98civichatch
98 civic cx to hx swap questions
Can I use a 92-95 vx ecu on a 98 cx? I got a complete swap from a 97 civic hx including engine, trans, Wiring harness, ecu, o2 sensor ,etc. I have heard the vx ecu is easier to keep in lean burn. i also just recieved a scan gauge 2 but the vss on the car only works sometimes and will sit at 20 mph when it doesnt want to work, going to get that working soon hopefully.
The scan gauge only works when the vss works?
Thank you in advance.
