Old 07-13-2014, 06:15 PM   #38 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by vskid3 View Post
I figured you would come to that conclusion after I saw the kind of grades you'll be driving on. Maybe with some aeromods and weight reduction you'll be able to stay in 5th.
Yea haha. And that's what I'm hoping for, I can almost, almost stay in fifth, but just not quite. I'm hoping with a proper grill block, underbelly pan, mud flap delete and repair of my dented hood + gap filling I will be able to, but we will see.
Originally Posted by California98Civic View Post
Your fourth gear is probably about the RPM/MPH range of a 1997 Civic EX. I drop to fourth in some places and in one place then down to third. No problem. Hill climbed. All I am doing is roughly matching what I used to do on the same hills in fourth of fifth with my old transmission. But with the CX/VX trans swap, I also have access to a much taller fifth when I want it for the flats cruising. Just downshift, you'll be fine on them thar hills. But I agree... don't swap a perfectly good HX tranny unless you have to. I only did the swap because I thought I needed urgent rebuilding in my old DX trans. It could use rebuilding, it turns out, but it was never urgent or necessary. I was miss-diagnosing a friction sound I was hearing.
You have to understand, it's not just a quick climb, the part of my commute I'm talking about is just around 8 miles.
