The swap is direct plug and play? Is there a pin out diagram for the vss from the vss to the ecu to the cluster? I am stumped as to why it works sometimes and then won't others? I found a tsb from honda about wires that rub through on the intake manifold but have already fixed that problem. Thank you.
