Originally Posted by Baltothewolf
Now this interests me, one can add a L/B indicator by simply adding an ECU that supports it? Is there already the wiring behind the cluster that allows plug and play or do you have to wire it yourself from the ECU to the cluster?
Not in my case, the car is a 96 lx civic. I added the lean burn indicator light to meet my ecu's capabilities. Had to pull the Gauge cluster and pay around in there to get it to work, but the stock ecu does support that function. I'm trying to see if there is an up shift light I can pin next, but I'm pretty comfortable with my "ear shift sounder" until then
