Old 07-14-2014, 12:14 PM   #7 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
As far as belly plan vs dam, you could do both. Air dams don't divert 100% of air, but the dam is much easier to put on and you can add the pan later.
There are good and bad ways to delete the power steering, I've read. I believe the best way is to connect the hoses in a loop in and out of the steering rack, it offers less resistance than just cutting the belt and leaving the pump in, while also keeping fluid in there and preventing things from drying out/falling apart. As CA98Civic said though, cutting the belt will provide immediate improvement.
