Old 07-14-2014, 09:12 PM   #13 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Yeah. There's a wing nut on the top of the power steeting pump mounting bracket, and a bolt on the side. Loosen those and you'll let off tension on the PS belt. I can't remember, but it might be the middle belt of 3, so it's possible you may have to take an A/C belt off too.
Uhg, if that's the case forget it. I'm to tired to do it right now, I'll figure out how to loop the lines (well, figure out what lines it is I need to loop) and pull everything off at once. I already know for a fact that I want to take it off, as I have tested all the 'sharp' turns I have to take with the engine off, and coasting so, I know I can handle it. Do any of you know a comprehensive guide on how to loop the lines and take off the p/s pump and everything that goes with it?
