Old 07-14-2014, 08:32 PM   #11 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
So I just replaced the Vtech solenoid gasket and it was definately bad on the right side (when facing the engine). The far right side bold had oil on the threads and all the way up to the head of the bolt, which it shouldn't have any oil on it at all, and the lower bolt was completely covered in oil. The left side bolt however was bone dry. I'm hoping this fixes the main leak but I'm not going to hold my breath.
Guys, is there anyway to remove the P/S belt without cutting it? It's brand new (came with the timing belt kit I just bought) and I would really rather not cut it, selling it would probably be a more favorable option.
Old 07-14-2014, 09:10 PM   #12 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Yeah. There's a wing nut on the top of the power steeting pump mounting bracket, and a bolt on the side. Loosen those and you'll let off tension on the PS belt. I can't remember, but it might be the middle belt of 3, so it's possible you may have to take an A/C belt off too.
Old 07-14-2014, 09:12 PM   #13 (permalink)
Furry Furfag
Uhg, if that's the case forget it. I'm to tired to do it right now, I'll figure out how to loop the lines (well, figure out what lines it is I need to loop) and pull everything off at once. I already know for a fact that I want to take it off, as I have tested all the 'sharp' turns I have to take with the engine off, and coasting so, I know I can handle it. Do any of you know a comprehensive guide on how to loop the lines and take off the p/s pump and everything that goes with it?
Old 07-14-2014, 09:55 PM   #14 (permalink)
I just came across this thread earlier today:
http://ecomodder.com/forum/showthrea...nes-29111.html
Old 07-14-2014, 10:29 PM   #15 (permalink)
Furry Furfag
This actually raises more questions then answers but thanks, I just need to get out there and start tearing it apart lolz.
Old 07-15-2014, 03:17 AM   #16 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Whenever you get around to removing your power steering... IIRC, the nut that holds the power steering pulley is reverse threaded...meaning
Lefty tighty , right loosey
It took me a good hour of twisting righty righty righty until I realized this
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 07-15-2014, 03:23 AM   #17 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Under the brake booster on the firewall
There should be 2 rubber hoses that stick out of the firewall (they should lead into the power steering reservoir). This is where you loop the hoses.
However, before you close the loop, then your wheel all the way to the left and right to releases most if the ps fluid. I say "most" because you still want a little fluid for lubrication.
If you don't do this step, there is no room for the fluid to move, thus steering effort will greatly increase.
Then you can start removing the power steering pump, pulley, and reservoir (optional).
Old 07-15-2014, 03:57 AM   #18 (permalink)
Furry Furfag
Well I went outside to remove the mud flaps, which I did, but since I was out there, I decided to take a look at the P/S belt. Luckily for me, it is the outside belt, so I pulled it off. While I was under my car looking at the underpart, I noticed the passengers side boot is ripped, how long can I drive it like this? It's a pretty big tear... (pics below).
Old 07-15-2014, 05:00 AM   #19 (permalink)
Furry Furfag
Well via my own research, I'm not going to risk destroying the cv joint so looks like the mamba is out of service until I replace it.... Sigh... I just really hope I can do this myself, I don't fancy the 2-300$ repair.
[Edit]: After seeing how easy it is to just replace the axle, I'm just gonna replace the entire axle instead. That way I'll have a lifetime warranty on it incase it rips again in the future. And with that being said, I'm just gonna keep driving it. I'll replace it on Wednesday or Thursday morning. I don't think it's going to go out on me in 200 miles of driving. It's not making any noise and there is still grease in the boot, so it must have just ripped recently
Old 07-15-2014, 08:54 AM   #20 (permalink)
I think you'll be fine. My experience has been that axles can last months or years after the boot tears. Maybe wrap it in tape to slow dirt from getting in and grease from getting out.
