Originally Posted by vrmouseyd15b
First thing I would check is the idle air control valve, second would be to try and "burp" the coolant system (my money is on a ditry idle air valve)
Well most recently, I did remove and thoroughly clean the idle air control valve. I sprayed it clean until there was nothing but clear carb cleaner dripping from it. It might be the cooling system. In fact, a flush and fill is my next task.
