If water and gasoline are in the same container, water is on the bottom. I've seen them together in a jar. Yellowish gasoline on top of clear water.
I once read an article about a gas station that pumped it's gas with water. The water was filled into the gas storage tank, and the water pressure pushed the gas out of the top of the storage tank and was directed to the fill nozzle.
