Old 07-20-2014, 01:20 PM   #6 (permalink)
jamesqf
Are you sure they are not confusing CO and CO2?
Exactly. AFAIK, no emissions test measures CO2, because (as others have already pointed out) the amount of CO2 emitted is directly proportional to fuel burned. Things that are measured, typically unburned/partially burned hydrocarbons (HC), oxides of nitrogen (NOx) and carbon monoxide (CO), are generally measured in parts per million, while CO2 is probably on the order of 20% (assuming complete combustion of the oxygen in the intake air).
