Old 07-20-2014, 01:31 PM   #7 (permalink)
oil pan 4
That is what I thought.
I only thought of this because last few shops I have worked at that did CO tests on heat exchangers that contained combustion wrongly had their CO detectors mislabeled as CO2 detectors.
It was the same identical industry standard CO detector each time and the fact that the machine its self was clearly labeled as and I quote " CO (Carbon Monoxide) detector" and the manual clearly stated it was a carbon monoxide PPM detector and I told them it was labeled wrong it still didn't get fixed.
They were using it correctly as a CO detector at least.
But the wrongly labeled CO detector is right next to the confined space CO2 detector. Hopefully no one confuses the 2.....
