Old 07-20-2014, 07:41 PM   #157 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
More progress: undertray, interior, nose
1. Undertray progress
Completed the rear diffuser template:
Cut from a roadkill diffuser the small venting holes I plan to use on my own diffuser, if possible:
My 25' roll of 2 or 3 mm thick x 22" wide black plastic arrived!
2. Frontend frustrations
I gave up on the road kill bumper cover and recycled it, after cutting lots of bits off without finding a way in which I would contribute usefully to lowering the stagnation point:
3. Interior mods progress
This was fun... I made a new center console panel using my daughter's throw away old looseleaf binder, bits of hardware I have saved, a box of mints, plasti-dip, a used gen 2 iPod touch, and some other random stuff. I bought nothing but the iPod Touch ($50) and the drill attachment for cutting the circular holes.
Using a little CAD I made a template of the shape I needed, then used it to cut the daughter's old notebook. Then I cut holes for mounting ultragauge, iPod Touch, and a USB port (as well as conduit lines so the wires car run through the panel into the dash:
Painted with black plasti dip, four layers:
Metal conduit for iPod wires, UG bracket, and USB port in place:
Mint box, cut to serve as iPod Touch stand:
Drilled and painted with plasti dip, four layers:
Completed installation:
ID:	15400   Click image for larger version
ID:	15401   Click image for larger version
ID:	15402   Click image for larger version
ID:	15403   Click image for larger version
ID:	15405   Click image for larger version
ID:	15406   Click image for larger version
ID:	15407   Click image for larger version
ID:	15408   Click image for larger version
The Following 4 Users Say Thank You to California98Civic For This Useful Post:
aerohead (08-23-2014), deejaaa (07-20-2014), OG VX (10-06-2014), PaleMelanesian (07-21-2014)
