Old 07-21-2014, 08:31 PM   #10 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
It seems the O2 sensor on these is not as critical as a lot of people think. It is critical to engine management, and if your O2 is bad enough to set off the check engine light, you will not get lean burn. But when the engine goes into lean burn it is in open loop and the air/fuel ratio is set by the computer, without the O2 sensor. There are a couple recent threads on EM where this topic came up. I was on the losing side of the debate, with the position I just described being correct instead.
I imagine the engine computer still monitors the 5-wire O2's finer wide-band data stream to protect the engine itself?
I looked at the FSM. The 1996-2000 FSM does not list the O2 or data that would come from it in the parameters for lean burn. It does say that a check engine light, for any purpose, will keep the car out of lean burn. Of course a VX is OBD1, not OBD2, but I don't think it is any different in this regard.
Normally, on this site, we have described the o2 as essential to lean burn, but apparently it is not.
