Originally Posted by Smurf
However, much of this effect can be minimized by not pouring large amounts at once, correct? For a grill block, let's say, you could fill the "deep" part about two inches, let it cure some, then add another layer to build up your depth? Will GreatFoam glue to itself to form a solid piece, or would it break off in the layers?
I think many of us have big ideas for GreatStuff but are intimidated by all these 'rules' ![Big Grin](/forum/images/smilies/biggrin.gif)
problem is, two inches expands to four to six inches, creates voids if not careful and the wands can only be used once. i've used it but not on a car. if your molds are thin material, it will push and deform it.
i will try two part next myself.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
