07-23-2014, 01:40 PM
#628 (permalink)
I've heard of carbon fiber "rope" being used if you happen to have some laying around. Finally plain old re-bar like you use in concrete work.
Basalt rebar, the alternative to steel and fiberglass for reinforcing concrete
Basalt Rebar is an alternative to steel and fiberglass for reinforcing concrete
Made from volcanic rock basalt rebar is tough, stronger than steel and has a higher tensile strength.
Much lighter than steel, 89% percent in fact!
