Old 07-24-2014, 02:28 PM   #11 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Saguache View Post
The cargo space behind the rear row is spacious, but hight may be the limiting factor when it comes to adding a disability scooter or a davit to lift the device in and out. That said, with some professional modification work there is a lot of empty space under the deck. Someone who knew what they were about could fix this by clearing out the spare tire and modifying the vehicle, even adding an electric ramp for the buggy.
Such rear floorpan lowering mods to provide access to wheelchairs or disability scooters are not so unusual in Europe, but I have never found any info about that into a Prius V. Anyway, sometimes it can even require the fuel tank to be relocated or replaced. IIRC the Prius V's traction battery is located in the same spot as in the Prius C, so at least it may not impose another issue to such project.
