If you had actually driven a hybrid you would know the same applies to the heater. At least some cars like the Civic and prius can run the ac on battery power for a few minutes before the engine needs to refire.
Me? I use recycle for air flow and let off the brake every so often so the engine runs a little, then reapply brake and auto stop restarts.
