Old 07-24-2014, 08:03 PM   #15 (permalink)
mbolton1990
mbolton1990's Avatar
eco-crx - '90 honda crx hf
90 day: 56.89 mpg (US)
Originally Posted by tvbd56 View Post
Well the one I have on there is actually a little smaller than the other ones and I was only able to fit two out of three screws but it still holds well enough.
After researching I'm pretty sure these are from 88-91 civics as well, and I remember taking parts off of civics around those years. (I looked at a lot of cars, they all blend in after a while)
I think with a little bit of work these could fit other cars too.
I also got a dipstick, cause the previous one was broken. I filled the car with 2.5 qts at the last oil change and the oil level on the previous dipstick was about a half a qt above full. I was confused and left it how it was, I ended up getting a dipstick at the pick-n-pull and put it in my CRX and figured out that the old one was the wrong dipstick and I was really a qt of oil low.
Damn previous owner didn't know what the hell he was doing
Shouldn't of hurt anything.
Some engines can run on as little as a quart of oil without damaging anything,think about it the oil pump sits in the very bottom of the sump and pumps that motor all through-out the engine regardless.Yea it's not ideal but as long as it's all getting oil flow no harm no foul.Not like I'm saying you can go and run your engine on a quart of oil now but I wouldn't worry about it too much.
