Old 07-25-2014, 04:48 AM   #65 (permalink)
Xist
Hey, it is strange how I periodically miss threads, this one is ten days old and seven pages already!
I have needed to make a disproportional amount of repairs to Chorizo for how much I drive it, but I plan on driving it for as long as I could. Mom called it "a money pit" and I mentioned that I could purchase my dad's Focus SFE, which has the same EPA rating, but seems to get better mileage in practice.
I will stick with the Honda.
The largest modification that I have done so far is the power steering delete, which I did not finish, because my life fell apart. I have hardly driven my car for six weeks, nor have I been in-town much to drive it. I decided to remove my power steering because I needed to replace my alternator, and my instructions said to remove the power steering pump. It certainly made it easier and it was still a difficult job!
I took pictures, planning on doing a write-up, and if you say please, I will finally take the time. The difficulty that I had was finding the proper fittings.
These are my [usually] relevant threads to date:
http://ecomodder.com/forum/showthrea...ual-29038.html
http://ecomodder.com/forum/showthrea...tml#post428591
http://ecomodder.com/forum/showthrea...nes-29111.html
For that second thread, it was already linked; I linked the last message, where I linked the parts to loop the hose. From what I have read, breathers are only necessary for certain types of racing, and NoD and others say the power steering fluid is not necessary for lubrication. The most important thing that I remember is to find a turkey baster narrow enough to fit inside the reservoir. I bought one for a dollar or two, but it was too wide, so I used a short hose to siphon it into a bottle. I would not disconnect the hoses from the pump or reservoir, that way you do not have fluid ruining your entire engine bay, just the rack and pinion, which will get it anyway.
I did an air dam, just half a roll of Home Depot lawn edging, with black self-tapping screws. It definitely works best to warm it up first, lay it in the sun, or boil it in a huge pot. There are flaps on each side and the one on the inside got in the way of the bumper, so when I redo mine, I will slit that every inch. I tried to shape it with a heat gun, but while some parts started tightening, others began sagging.
Then I made something like an air dam. I just cut a section of coroplast, I believe that it is 36" wide and 18" tall, with two holes for the license plate holder screws. It is terribly ugly, but should be effective.
I will try to put together the power steering deletion thread.
