Old 07-27-2014, 02:35 PM   #171 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 52.92 mpg (US)
Hey Bob,
Perhaps you could check your rhetoric just a tad. Sendler's been here for a while now and by his numbers doesn't appear to be completely clueless - whereas you have not "put up" at all.
Sendler:
I think the decomp lever is a great thing to control from inside the car. For starters CJ posted some bonkers numbers in his GGP, so he must be doing everything, or nearly everything, right - including the decomp control.
Triggering the decomp while coasting will take a lot of drag off the engine, whose rotating mass then adds its inertia if left in gear to the car and make it glide after downhills as if it were a larger car. Not only that but it will also do a fair amount of air cooling which may help prevent the electric fan coming on during operation, a not-insignificant savings.
