Old 07-29-2014, 01:24 PM   #5 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Push is pretty much the same as bump, and as far as I can tell the concern is negligible.
However you start the engine, everything is cold upon starting. Some uncombusted fuel is going to make it through. I can't see how push starting the engine puts it into a significantly different operating paradigm than conventional starting.
Bump starting is just like push starting, except everything - including the cat - is pretty close to operating temperature. I think Ford is just hedging against possible damage claims.
