Old 07-31-2014, 04:56 PM   #97 (permalink)
darcane
darcane's Avatar
I have yet to find a good way to get the manifold OUT of the car. There is one bolt/bracket that is holding it on yet and it does not seem easy to get to. I will take it out and weld up the manifold though.
I was wondering if I could weld it in place and use the head as a fixture to keep it from warping. Not sure if that is a good idea or not.
I'm planning to buy 06110-PLD-010 - GASKET KIT, CYLINDER HEAD which should include:
12251-PLC-004 Head Gasket
17055-PLD-004 Intake Mani Gasket
18115-PLC-J01 Exhaust Mani Gasket
12210-PZ1-004 Valve Seal A (x8)
12211-PZ1-004 Valve Seal B (x8)
12342-P2A-005 Spark Plug Tube Seals (x4)
91213-P2F-A01 Camshaft Oil Seal
90442-PLC-000 Rubber grommet-washers for the Valve Cover bolts (x5)
12341-PLC-000 Valve Cover Gasket
19411-PLC-003 Water Passage Gasket
Now that you are "done", is there anything else you think I would need to replace? I think head bolts are needed, but I'm having trouble finding them on Majestic.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
