Old 08-01-2014, 01:56 PM   #22 (permalink)
sarguy01
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
Originally Posted by jamesqf View Post
Simply not true, if you are going for max fuel economy. As for instance, one road I drive on often (lightly travelled, limit 50 with most people doing close to 60) has a fairly small hill. If I start up it at 50-ish, my speed will drop to about 45 at the top, then if I let off the gas, I'll be back to 60 by the time I reach the bottom. So if I hit the brakes to maintain legal speed down the hill, then I'm wasting fuel.
Then there are all the real hills hereabouts, where I can easily get up to 85+ while in gear and getting some regen too.
Valid.
I live in a flat area. The only way to get above the speed limit is to use the gas pedal.
