Old 08-02-2014, 07:32 PM   #4 (permalink)
oil pan 4
As the weather changes you need to change rods and jets to maintain your ideal A/F mix.
Usually once you get it nailed down, with an edelbrock 650 carb you can limit almost all tuning to swapping out the primaries metering rod, which takes about 5 minutes or less depending on how easy your air cleaner is to remove.
Stacygifford (08-02-2014)
