Old 08-03-2014, 08:42 AM   #32 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Did you ever replace the EGR valve? Sounds like the cleaning may not have worked on that part. The symptoms you're describing sound like you haven't sorted that out yet. The valve itself could be blocked, or the electrical traces that indicate the valve position status to the computer may be worn out.
