Originally Posted by iveyjh
Tried changing the wide band sensor?
No I haven't done anything yet to try and solve this issue except for Sea-foam. It helped the idle a little bit (would idle at like 250rpm and make it hard for a noob to take off) but other then that no.
The sensor is going to cost me $150 so I'm a little hesitant to just go and change it. Also is the lower sensor suppost to be a narrow-band? Because I was looking at it today and the upper one has 5-wires (wideband) and the lower one only has 4-wires (narrowband?).
