Old 08-04-2014, 05:50 PM   #7 (permalink)
aerohead
upper grille
Originally Posted by keepinitsimple View Post
Fellow civic owners, do most of you block the upper grill area completely or leave a portion or leave a portion open for the radiator? I've been debating if I should block it completely or partially due to the high temps here in Texas?
I wanted full flow to as much radiator as I could get,so I left the nose intact and created a new nose over it and a little further forward which had a reduced entry into an airtight duct which fed everything internally.
