Old 08-04-2014, 09:43 PM   #18 (permalink)
silvermazda
Miata - '00 Mazda Miata
90 day: 27.57 mpg (US)
Celica - '91 Toyota Celica GT
90 day: 18.1 mpg (US)
Originally Posted by serialk11r View Post
I think you have the right idea. Adjust the intake cam to reduce volumetric efficiency in the low range. I would buy a piggyback to tune.............I would also look into having the head shaved down a little for raised compression if you have it out for cam replacement. The adjusted intake cam should allow it.
Mhm. I had a ecu, but I couldnt dial it in to produce reliable starts and since I had work, it didnt stay around. But for the most part it isnt problematic, just my unit was. When I have more time I will invest in another one.
As far as engine work, again, when the time comes. The engine is healthy, rebuilding it now at 112K miles would be premature.
UPDATED MAIN POST
Planned mods/Aero.
