Originally Posted by Joris
You're right, it is blocking the rear view. I can see about 20-30 meter behind the car. Best would be an open view to the back, but that is not possible. So I will have to do with it. Parking is no problem this way.
But, I sometimes have to drive a van for work. And those vans also don't have a rear window. So I am a bit used to not using the rear view mirror.
@ Renault_Megane_DCI
That would be great!
Do you know if driving in France with something like this on my car will get me pulled over? Are you allowed to have shiny aluminium sheets on your car there?
You might be able to just insert a square section of the acrylic so you can see some of the field of view. Or you might insert two pieces side by side, separated by a seam of aluminum sheet in the very middle? Although, LEXAN is better to work with I think...
