Old 08-07-2014, 01:17 PM   #174 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Arcosine, thanks for the link to those GM codes.
Here's the inside of the glovebox on my truck.
One of the codes is GT5, which indicates rear gearing of 4.10. I believe this was the lowest stock gearing available on S-10s. That would make sense, since it's the 2.2l 4-cylinder (less powerful engine) AND extended cab, which makes it heavier.
I believe that the low gearing would be a disadvantage to the diesel engine, but an advantage to the electric motor. Likely, I'd have a relatively low top cruising speed on the diesel. If it were somebody else, that might be a problem, but I don't mind keeping my speed reasonable on the freeway.
I think the 4.10 gearing should be fine.
EDIT: I also looked in the junk truck. That one says GT4 on it, which would be 3.73 gears. That truck really is junk. I only have it as something to test-fit and experiment on. I wouldn't want to use it's whole rear differential, but if I really wanted to, I'm sure I could take it apart and get that gear out.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
