Old 08-07-2014, 04:22 PM   #10 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Thanks guys! I guess a little bit more info would be helpful...
I am getting a trans cooler for my 4runner to bypass the radiator. The 4R is well known in certain circles to have a 'pink milkshake' when ATF and coolant mix from the radiator going bad. To prevent this, I am going to install a trans cooler.
So what I'm interested in is first, does the cooler make the trans take longer to warm up or does it not 'open' until the ATF gets to a certain temp threshold? Second, if sized too large can the cooler actually over cool the ATF after it gets to operating temp.?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
