Old 08-07-2014, 11:34 PM   #115 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Baltothewolf View Post
Idk why but I thought I posted this hours ago but I guess it didn't stick? I have no idea what happened. Anyway, I finally did a compression test and here are my results.
Cylinder #4 = 180
Cylinder #3 = 180
Cylinder #2 = 160
Cylinder #1 = 165
I'm not sure if this warrants concern or if it's ok, but a 11.2% variation from highest to lowest is worrysome, as I have read that 15% is when the CEL will kick on for a mis-fire.
At a 9.4:1 compression ratio I think you should see about 200 on your test, ideally. I've seen people not complaining about 180+ much. Adjusting valve clearance, I read, by increasing it--perhaps to max spec.--can help with compression. Did you check clearance on #1?
