Old 08-08-2014, 11:19 PM   #21 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Hmmm... I wonder if a factory thermostat would work and I could somehow modify it to open at a set time. Maybe this project is going to require an Arduino with a sensor, relay and e-valve. Didn't really want to do that, but if push comes to shove I just might.
oil pan, I like the idea of having the two coolers, my two issues are that I want it to be fully automated (anybody can drive the truck without 'forgetting' to open/close any valves), and that I am not going to use the factory cooler, to prevent any future damage, which means I would need two coolers.
In your scenario, how would you run the electronics/valves? Would you have some sort of temp. sensor with a relay to the valves? Is there a logic board in there somewhere?
EDIT: What about this? If I sent this to a relay to open a valve, would that work for me?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
