With 3 or less inputs and 2 outputs there is no need for a logic board. Electro mechanical will work fine.
Something like that switch you found on amazon would work, just finding them in the correct temperature ratings can some times be difficult.
Well that makes my life easier! The Amazon page says it has 'turn on' at 180* and 'turn off' at 165*. So I can attach it to a relay and operate a valve to open and close the line into the cooler. Now I just need to find a valve with a 'tee'...
