Thread: Yes!
Old 08-10-2014, 10:03 PM   #1 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Yes!
Glee, man. I am on the road again. Completed: valve lash/clearance adjustments, timing belt and tensioner replacement, one engine mount replaced, helicoil fix of a stripped valve cover bolt housing. Partially completed: oil pan gasket replace and undertray/diffuser build. I actually have hardware for the undertray framing and mounting hanging under the car, and some of the panels are cut, including the diffuser. Too much repair, too many snags, too many little errors to correct.
Glad that's done. Car runs slightly differently: low idle (550-600 a lot of the time) and high alt output when I ran it (13.9 volts alot of the time).
user removed (08-10-2014)
