Thread: Yes!
Old 08-11-2014, 12:40 PM   #8 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by digital rules View Post
... Also thought if valve clearances are adjusted too tight, the risk of burnt valves increases due to inadequate heat transfer to the head?
Apparently they tighten with wear. But my reading online seems to match yours: too tight means less heat transfer and a few other things not lovely. So I set them to MAX spec, which means they are set to the most loose position permissible. (I was conservative as to how I measured that on the feeler gauge because I was concerned about measuring poorly and having too loose and so my lash is likely slightly less than maximum.)
Originally Posted by Old Mechanic View Post
Now you know what to expect.
Yes, I do. And thanks for the tutorials on it.
