Old 07-14-2008, 06:50 PM   #5 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by tacodan View Post
A question if I may? When coasting down a long grade, is it better to shift to N and let out the clutch pedal, or is the fuel injection shutting down if I coast down the grade in gear.
Glad to be here,
TacoDan
Glad to have you here.
3 options
1) Leave it in gear; down shif as needed to keep it over 1200 rpms (safe fuel cut off rpm without scangauge) You will slow down faster than 2 and 3! (it is what I do most of the time)
2) throw it in neutral More coasting distance, but you are burning fuel. CAN be best option for some situations
3) put it in neutral turn off the engine. Best Fuel economy, best coasting distance. HOWEVER BE CAREFUL! there will be no power steering, limited power brakes, make sure you don't lock your steering wheel.
All depends on your comfort level/ situation. if you use #3 try it a few times in an empty parking lot to make sure you are comfortable/ safe with it.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
