Old 08-13-2014, 01:51 PM   #6 (permalink)
cRiPpLe_rOoStEr
So, is your Cherokee fitted with that 2.5L VM Motori engine or with the 2.1L Renault engine? If you're lurking about a VGT upgrade, why not eventually a whole engine swap? Anyway, I have already seen some mechanically-governed engines fitted with VGT, such as the International 2.8HS used in Argentinian-made versions of the Ford Ranger.
