Originally Posted by Baltothewolf
Aren't engine block heaters 200$+?
I thought they were $90..... at least that's how much Ford advertises as an addon for Fusion's engine.
Aero is irrelevant at city speeds, but stop/go is a killer because you use ~50000 watts to get moving & then waste the energy as heat when you brake.
I'd strip your car of rear seats, carpeting, sound-deadening materials attached to the hood. Go on a diet.
Anything to shed 1000 pounds. Of course the ideal car would be one weighing less than 2000 pounds... like the aluminum insight.
