Old 08-14-2014, 03:04 PM   #13 (permalink)
darcane
darcane's Avatar
Agreed- cornering can be improved.
There were a couple of occasions I wanted to measure ride height; one was the camper truck laden vs unladen and the other was when I lowered my Coupe. It was then I discovered I couldn't measure to the ground- even on what appears to be a decent concrete slab- because the measurements were all over the place, far too large to make the measurements of any value. It was then I discovered I could get better measurements by leaving the ground out of it, by measuring from the tops of the tires to the inner wheel well. The Coupe got lowered approximately 2" and it looks like your before-and-after.
P.S. The ground is still "in it" because the vehicle is parked on it, but the measuring errors are less. Concrete slabs are deceptively uneven.
I typically measure axle centerline to wheel well for the same reasons. That gives me two hard points to base changes off of, and compare front to rear (since the tires are slightly different sizes).
I did a similar lowering on my Civic. Before and after looked very comparable to the OPs pics (his maybe a smidge lower up front). It was about a 2.5 inch drop. Mine scrapes too much as it is, I couldn't imagine going any lower.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
vrmouseyd15b (08-14-2014)
