Old 08-14-2014, 11:55 PM   #6821 (permalink)
jedsmd
PLUGnGO
jedsmd's Avatar
The the new hall effect PB-6 throttle box clone has arrived from China. I have installed it on the truck and made the wiring changes to the controller board.
It came without a datasheet of any kind so I had to wire it by trial and error. If anyone else buys one of the ones off eBay the wiring for mine was:
+5v - Blue wire
Signal - Black wire
Ground - Brown wire
Measured voltages are:
Zero Throttle +0.20 volts
Throttle contactor closes +0.20 volts
Max throttle +3.95 volts
There is a small flat area at the low end before voltage starts climbing which is why 'zero throttle' and 'contactor closes' voltages are the same.
Paul
Please send me some spread spectrum code
Thanks
Jerald
The Following 3 Users Say Thank You to jedsmd For This Useful Post:
Astro (08-15-2014), MPaulHolmes (08-15-2014), thingstodo (08-16-2014)
