Originally Posted by soulcrusher
Air and fuel mixes are relative in that an air filter sets the maximum air into the engine.
Instead of being all air and adding gas for loads, vapor running would be more "all gas" and restricting air for loads. Either way
Except in this case the fuel is introduced from behind the throttle plate, so reducing air is easier then demanding more vapor, just like your air filter, the supply only needs to be enough for high demand, only fuel needed is drawn
