Originally Posted by soulcrusher
Awww. This is my custom air flow controller since the engine runs opposite to normal. All the gas is always ready, just add air. It's connected to the throttle body control and adjustable. You see the pcv and temp sensor in the replacement air connection. For day 3
Good pictures and progress reports. Keep it up. Don't let others dissuade you.
I would like a diagram and a clearer idea of where you may be going with all this. Hand drawn pictures are acceptable. Setting your working principles before you build can save much time and effort.
