Old 08-20-2014, 01:11 PM   #1 (permalink)
slogfilet
VX Padawan
VX du Slog - '94 Honda Civic VX
Installed my mpguino - Civic VX
Finally got it in! I used Posi-Taps to tap the VSS and injector wire near the ECU, then used the 12v constant and ground from my radio to provide power.
I considered myself a good mpg-er previously, but this adds a whole new level. It's very easy to see how some of my previous assumptions about engine load and speed were incorrect. For example, I can tell instantly when I drop out of lean burn and need to downshift on a slight hill.
While a good solder job is the best way to do it, I highly recommend Posi-Taps. They're secure, removable, and minimally intrusive.
I have it sitting in the hole where my clock delete plate was. Just need to make a little bracket, and possibly add a 4-pin Molex connector so I can take it out easily.
This is version 1.1 from Quezacotl... highly recommended. Shipping was fast and well packaged. He is now selling v1.2, which looks even better.
The Following 2 Users Say Thank You to slogfilet For This Useful Post:
Coreycolman (08-12-2015), leety (11-19-2014)
