Old 08-21-2014, 03:20 PM   #11 (permalink)
SilverCrown9701
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
Originally Posted by digital rules View Post
If the speed bumps are properly engineered, you should be able to maintain the posted speed limit w/o the need for constant braking. Unfortunately this doesn't always hold true, so YMMV. Can't really pulse & glide with those nasty speed bumps around
Most drivers around here race up to speed bumps & then over brake to compensate. (this is when the skilled hypermiler catches back up with them & gets pissed cause it screws up their better thought out strategy) I still don't understand the mentality of most drivers who just drive soley with emotion & zero common sense.
I try use just enough momentum to keep me going from one bump to the next.
I usually just idle through stop signs.
My car is an automatic so I know that EOC is not good for it.
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
