Old 08-21-2014, 02:30 PM   #1 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
A/C vs MPG test: impact of air conditioning on fuel economy (2015 Nissan Micra)
Nothing ground-breaking here, but while I was test driving the new Micra, I decided to find out how much of an impact the A/C had on fuel consumption over a range of speeds.
(As an aside, these Micra results would also apply to the 1.6L Versa Note and Versa sedan. Same platform/drivetrain/components.)
I ran a bunch of bi-directional runs at 3 different speeds with the A/C on and off. The fan was left on the 2nd speed for all the runs, just toggling the A/C switch.
Results...
(Note: I graphed it for L/100 km, so those of you used to seeing graphs of "MPG" where the taller bar means better fuel economy, keep in mind it's reversed in this case.)
From: AC vs. MPG: impact of air conditioning on fuel economy tested - Micra-Forum.com
The average fuel consumption increase with A/C on vs. A/C off was 5.9%.
In retrospect, I wish I'd done a couple more 100 km/h runs, since it seemed to show that the A/C impact is smaller at higher speeds & engine loads. Though it makes sense that it would be, since you're covering more ground for a given power draw, plus the engine is probably sitting in a more efficient part of the BSFC map while it's providing that power to the compressor.
Code:
speed   AC      N.      S.      avg L/100 km*
60      off     4      4.1      4.05
        on      4.3    4.4      4.35
        on      4.3    4.5      4.37
        off     4.2    4.1      4.16
80      off     5      4.5      4.75
        on      5.5    4.7      5.10
        off     5      4.5      4.75
100     off     6.3    5.6      5.91
        on      6.6    5.8      6.15
(* Some of the averages are affected by rounded conversions of initial
readings that were taken in MPG)
ID:	15627   Click image for larger version
ID:	15628   Click image for larger version
The Following 12 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (08-22-2014), ecoTex (08-22-2014), fusion210 (08-22-2014), gone-ot (08-21-2014), jeff88 (08-21-2014), LeanBurn (08-22-2014), mcrews (08-23-2014), PaleMelanesian (08-21-2014), redpoint5 (08-21-2014), sendler (08-23-2014), some_other_dave (08-22-2014), Xist (08-23-2014)
