Old 08-24-2014, 03:23 PM   #42 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by CargoBoatTails View Post
Well bigger tires can cause premature wheel bearing wear and damage wheel wells, especially if you go wider. For instance, if you have a 245/45/17 you shouldn't go to a 255/45/17, you should go to a 235/50/17, kind of like Porsche does now and Lotus use to.
ANd driving with your windows down in the rain will eventually mildew your carpet.......
(but we are smart enough to know that)
I can't think of one person in the 4 yrs I've been here who put on a taller tire that rubbed the wheel well.
Why?
Because the idea is to put a tire that is SLIGHTLY larger diameter and DOES NOT RUB!!!!!
And as a factual note: when I used TIRERACK.com recommended installer, they actually ordered a larger diameter tire and tried it out beforehand to make sure it didn't rub the wheel well.
Please show PROOF of someone here suffering premature wheel bearing wear.
Again, a slightly oversized tire MIGHT weigh 1-2 lbs more that the size it replaces. There is plenty of over-engineering in wheel bearings to handle that slight increase.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
